  • BIM news
  • BIM projects
  • EN
  • Menu Menu
List List Menu
  • BIM and Construction Sites
  • BIM and Building Design
  • BIM in Construction
  • BIM and Estimation
  • BIM and Energy
  • BIM and Safety
  • BIM and MEP
  • BIM and Facility Management
  • BIM and training
  • BIM and GIS
  • BIM and Infrastructure
  • BIM and technical standards
  • IFC and openBIM
  • Digital Twin
Home » BIM in Construction » Line of Balance in Construction: A Complete Project Planning Guide
The line of balance in construction is a project management tool focused on the sequentiality of activities in the process. Here is a complete guide
Editorial Team / 13 June 2025
Project management in construction is a process of organizing all phases of a construction process, ensuring that it is completed within deadlines, costs, and quality standards.
In the field of project management in construction, there are numerous techniques to manage the lifecycle of a project, and among these, we cannot fail to mention the line of balance (LOB), widely used when it is possible to break down the process into multiple activities and repetitive sequences.
In this article, we aim to provide a comprehensive overview for understanding the LOB and we will learn how to apply it to our projects and how BIM tools can integrate LOB planning.
  • What is the Line of Balance (LOB)?
  • Fundamental Principles of LOB in Construction
  • How to implement the Line of Balance in construction projects
  • Steps to implement the Line of Balance in your projects
  • How BIM tools can integrate the planning of the Line of Balance
  • FAQ – Line of Balance (LOB) in construction
The Line of Balance, or LOB, is a control and management process used in construction to collect, measure, and present information related to time, costs, and results, all in relation to a specific plan or project.
It mainly applies when it is possible to break down the work into multiple sequential work activities, which are represented through a single line on a chart.
It differs from a bar chart that shows the duration of a particular activity because this technique shows the speed at which the work must be performed to meet the scheduled times, as well as the relationship between one activity or process and the subsequent activity or process.
In the project planning process, the choice is always influenced by the type of project and the requirements.
But what are the differences between the LOB technique and other traditional planning techniques? Let’s find out together.
LOB vs Gantt Chart
The Gantt chart is a horizontal bar chart that sequentially outlines activities over time, showing the relationships and dependencies between various activities.
Compared to the LOB, the Gantt chart represents a much more rigid planning technique, which applies to well-defined sequential activities.
The LOB, on the other hand, is much more flexible with activities that are repetitive and can therefore vary over time.
Additionally, with the Gantt chart, activities and their progress over time are monitored, while with the LOB, the workload is monitored.
4D BIM model with Gantt chart
4D BIM model with Gantt chart | usBIM.gantt
LOB vs CPM
The CPM (Critical Path Method) is a project planning and management tool that is based on identifying the set of project activities that are critical for meeting the time required to complete the work. In fact, the critical path represents the longest one, that is, the one through which more time is spent.
It is clear that CPM, compared to LOB, focuses on the time variable; the focus is on the duration of the project and is therefore used when one wants to concentrate on planning and controlling time.
The fundamental principle of LOB in construction is the optimization of the transformation flows of construction within the construction process, aiming to facilitate the control of development through the successive phases.
Optimization is made possible by the identification of the main process phase and the state of completion of the construction: in this way, the actors can improve the flows related to the management of prerequisites and, therefore, meet the actual needs of the moment, trying to eliminate the excess of resources compared to production rhythms.
LOB mainly consists of four phases:
  • definition of the objective;
  • drafting of the program;
  • monitoring of the progress status;
  • comparative analysis between progress and objective.
The application of LOB is very useful when working on processes that could be affected by many unforeseen events, whether predictable or unpredictable. This is because LOB allows for the immediate identification of work locations, phases, involved personnel, and the intensity of the work performed, which can be crucial both for quantifying the expenses incurred (or to be incurred) and for resuming work even after a period of time.
LOB in Construction
LOB in Construction
Advantages of implementing the Line of Balance in construction
The advantages of using the LOB technique are:
  • a better understanding of the amount of work that each person must perform at a particular time;
  • a better efficiency in planning, with accurate rhythms that allow for a concrete determination of the duration of each phase of every activity;
  • an optimization of resources, in relation to repeated work activities;
  • a better analysis for optimizing time and costs;
  • a greater customer satisfaction, due to timely deliveries;
  • a greater ease in modifications, updates, and changes in scheduling.
The effective implementation of the Line of Balance in construction projects requires a strategic and well-structured approach.
The heart of the LOB is the graph: on the vertical axis, the different physical units of the project are indicated (e.g., floors of a building, road segments, apartments), while the horizontal axis shows the timelines.
Each line represents a team or activity that progresses over time through the physical units. The slope of the line indicates productivity: the steeper it is, the faster the activity.
To create and update an LOB diagram, you can use:
  • dedicated software;
  • advanced spreadsheets;
  • integrations with BIM or ERP software to automate data.
Concrete example: construction of a 10-story building
Suppose a project involves repetitive activities such as:
  • construction of the structure,
  • electrical systems,
  • finishes.
Each team must complete a floor in 5 days. The LOB allows you to:
  • visualize when each team must start on each floor;
  • understand if there are risky overlaps or empty time slots (waste);
  • adapt work rhythms, anticipating recovery margins in case of delays.
A correct implementation does not only concern individual activities but also their interdependence. For example:
  • the electrical systems can only start 2 days after the structure;
  • the finishes must begin after the systems, but on multiple floors simultaneously;
  • with the LOB, it is possible to simulate these scenarios to achieve the most efficient flow possible.
To correctly apply the Line of Balance technique in a construction project, it is essential to follow a well-defined sequence of activities that range from initial planning to visualizing the operational flow through a diagram. Here are the key steps to implement it effectively:
  1. clearly define the project objectives:
    establish clearly the desired outputs, budget, available resources, quality standards, and time constraints. This is the starting point for any accurate representation;
  2. break down the project into activities:
    identify the tasks that repeat over time and space (e.g., floors of a building, housing modules, production units). Group similar activities and order them based on their logical sequence;
  3. detail each activity:
    for each task, define: what needs to be done, what resources are needed, which teams will be involved, and what the estimated duration will be. Consider any buffers and production variables;
  4. estimate the duration and quantities to be completed:
    assign a specific duration and quantity to each activity (e.g., 5 days to complete a floor). This will be essential for accurately representing the slopes of the lines in the LOB graph;
  5. define the dependencies between activities:
    order the activities based on their prerequisites. For example, the electrical installation can only start after the structure, while the finishes begin after the systems.
  6. create the LOB graph:
    on a vertical axis, represent the physical units (e.g., floors 1-10), on the horizontal axis the working days. Draw the lines for each activity, with a slope that reflects the production rhythm.
Key steps to implement the LOB
From these basic steps, one can proceed to create the timeline with the main milestones of the project and monitor progress against what was planned, gradually updating it.
Efficient planning is essential for sustainable construction projects, and traditional planning approaches certainly do not make this possible, lacking adaptability, visualization, and integration with modern technologies.
To address these planning issues, the main cause of delays and cost increases during execution, efforts have been made in recent decades to integrate this process with BIM tools and software.
A BIM project management software allows you to optimize the planning process in various ways:
  1. optimal information management, thanks to the use of BIM models suitable for the required level of detail;
  2. optimized collaboration, by comfortably working online on construction projects, you can collaborate in real-time with design, execution, and maintenance teams through chat and online meetings;
  3. project execution management, by breaking the project down into multiple activities, it is possible to better understand the actual progress of the execution;
  4. time and cost control, during the design phase of the work, time and costs are generally estimated, but during execution, it will be very useful to monitor actual times and costs activity by activity;
  5. process automation, by linking your Line of Balance to the BIM model, as the project changes, the phases and their sequence will automatically change.
To fully leverage the potential of the Line of Balance, use a BIM project management software: it will allow you to plan, control, and adapt each phase of your project more intelligently, quickly, and effectively.
What is the Line of Balance (LOB) in construction project management?
The LOB is a project management and control technique that allows for the graphical representation of the progress of activities concerning time and physical location. It is particularly useful in projects with repetitive activities, such as multi-story buildings, housing modules, or linear works. It allows for visualizing the workflow and monitoring operational efficiency in real-time.
How does LOB differ from techniques like Gantt charts or CPM?
Compared to Gantt charts, LOB is more suitable for repetitive activities and focuses on production rhythm and workload, not just on the duration of activities. Unlike CPM, which identifies the critical path based on total duration, LOB highlights the interaction between project phases concerning space and time.
How is LOB implemented in a construction project?
To implement LOB, it is necessary to:
  • clearly define objectives and resources;
  • break the project down into repetitive activities;
  • detail each task and estimate its duration and quantity;
  • represent everything on a chart where the lines indicate the progress of teams concerning time and space.
What does the LOB chart represent and how is it read?
The LOB chart has two axes: the vertical axis indicates the physical units of the project (e.g., floors), while the horizontal axis represents time. The lines indicate the progress of activities. The slope shows productivity: the steeper it is, the faster the activity. It allows for identifying overlaps, slowdowns, and bottlenecks.
How can BIM software support LOB?
BIM software allows for integrating LOB planning with:
  • optimized information management;
  • real-time collaboration;
  • detailed control of time and costs;
  • process automation: changes to the project automatically update the phases in the LOB chart.
usBIM.project
usBIM.project
Share this entry
  • Share on Facebook
  • Share on X
  • Share on WhatsApp
  • Share on LinkedIn
  • Share by Mail
Related posts
    27 August 2026
  • BIM and VR: Transforming the Construction Industry
  • 23 July 2026
  • BIM SROI: Measuring Social Value of Construction and Infrastructure
  • 26 June 2026
  • The advantages of BIM Maturity Level 2
  • 18 June 2026
  • Historic Garden Restoration: The Case Study of Villa d’Este
Follow us on
  • Construction Sites
  • Energy
  • Estimation
  • Infrastructure
  • Safety
  • Structural Calculation
  • Technical standards
  • Training
  • BIM news
  • BIM project example
  • Digital Twin
  • IFC and openBIM
Scroll to top
