Incorporating BIPV technology into buildings
Building integrated photovoltaics is a panel structure that replaces roof covering elements. Solutions and advantages
Whether it is a residential building or an office complex, photovoltaics are one of the most common solutions for self-production of renewable energy. Thanks to technological advancements, in addition to energy production, photovoltaics also become a true design element.
Building integrated photovoltaic panels are an example of how it is possible to integrate systems with architecture. These are systems that are designed within the building project itself or, subsequently, architecturally integrated. Therefore, it is not the classic roof-mounted system, but a structure that becomes the covering material at the same time.
An integrated approach is necessary to best implement a photovoltaic system of this type, allowing for the evaluation of all architectural, structural, energy, and functional aspects (and constraints) of the project together. In this case, a photovoltaic software with 3D modeling could be useful, enabling the design of the system directly on the architectural model and the evaluation of different design solutions.
What are the differences between BIPV and traditional solar panels?
The main difference between a building integrated photovoltaic (BIPV) system and a traditional photovoltaic system concerns the role that the modules play within the building.
In the case of traditional solar panels, the system:
- is installed after the construction of the building;
- serves an exclusively energy-generating function;
- requires dedicated support structures;
- does not replace existing building elements but overlaps them.
The integrated photovoltaic, on the other hand:
- replaces parts of the building envelope, such as roofs, facades, sunshades, or glazed surfaces;
- produces electricity and, at the same time, contributes to the constructive and architectural functions of the building;
- participates in protection against weather agents, insulation, and, in some cases, control of natural lighting.
A substantial difference also concerns the design process:
- traditional systems can be installed on existing buildings without significant structural interventions;
- BIPV systems require integrated design from the preliminary stages, with the coordinated involvement of architects, engineers, and system designers.
From an aesthetic point of view, BIPV allows for:
- a greater formal and material continuity with the architectural language of the building;
- a reduction in visual impact compared to panels applied on top.
This advanced integration generally entails higher initial costs compared to traditional solutions, which are offset by the architectural, functional, and energy benefits obtained in the long term.
Differences between BIPV and traditional solar panels
- Why choose a building integrated photovoltaic system?
- Building integrated photovoltaics: types
- Design Considerations for Building Integrated Photovoltaics in Modern Architecture
- How Do BIPV Systems Affect the Energy Performance of Buildings?
- Building integrated photovoltaics: advantages and disadvantages
- The best use cases for building integrated photovoltaics in urban areas
- The challenges of installing BIPV and how to overcome them
- BIPV and building regulations: what to know before installation
- How much does a building integrated photovoltaic system cost?
- How to design and model Building Integrated Photovoltaics (BIPV)
- Trends and emerging technologies in BIPV applications
- FAQ on building integrated photovoltaics (BIPV)
There are several reasons why it may be necessary to consider the installation of a building integrated photovoltaic system. These reasons are mainly attributable to two factors: aesthetic and necessity.
From an aesthetic point of view, a building integrated photovoltaic system offers a visually more pleasing appearance because the solar panels do not protrude from the structure’s envelope. This solution is suitable for buildings with a specific architectural style, such as historic houses, farmhouses, or other buildings with particular architectural features.
The other reason why it may be necessary to install a building integrated photovoltaic system is related to landscape or cultural constraints. These constraints may concern both the building itself and the surrounding area.
In some cases, property owners subject to such constraints are obliged to comply with local authorities’ directives to preserve the area’s aesthetic appearance. Therefore, the installation of a building integrated photovoltaic system becomes the only option to comply with these regulations and, at the same time, benefit from solar energy.
The various types of building integrated photovoltaic systems depend on the level of integration with the building surface where they are to be installed.
There are therefore 3 types:
- Building integrated photovoltaic system on the roof;
- Partially integrated system;
- Non-integrated system (in this case, the system is anchored to the building surfaces through the use of specific supports and fastening tools).
As mentioned earlier, in a building integrated photovoltaic system, the panels completely replace the roof covering elements. In this case, the system serves a dual function: not only producing electrical energy but also protecting the building from the weather.
This solution, however, is also suitable for use in existing structures. In this case, the photovoltaic system will replace tiles or portions of the roof, thus removing the old structure.
The partially integrated system represents a compromise between an integrated and a non-integrated system. In this case, the photovoltaic panels, while being anchored to the roof, slightly protrude from the building’s external envelope. They are not an integral part of the building structure but are considered an independent structure.
The installation of panels for this type of system does not alter the structure on which they are installed. They only serve the function of producing electrical energy. This approach is often adopted on pitched roofs, where it is possible to take advantage of the roof’s natural inclination without having to install visible or significantly tall supports.
The non-integrated system is anchored to the building surfaces through supports and weights. Since they are anchored to existing structures such as roofs or building facades, the panels will be visible. In this case, the photovoltaic panels serve exclusively the function of producing electrical energy.
The integration of photovoltaics in contemporary architecture requires a multidisciplinary design approach, where energy production is combined with the aesthetic, functional, and performance needs of the building. Designing a photovoltaic system is a fundamental phase to ensure optimal performance, correct architectural integration, and compatibility with the building envelope. Unlike traditional systems, building integrated photovoltaics (BIPV) directly influence the configuration of the building envelope and must therefore be evaluated from the preliminary phases of the project.
Among the main aspects to consider during the design phase are:
- the orientation and exposure of the photovoltaic surfaces;
- the relationship between energy production and envelope performance;
- integration with the building’s mechanical systems;
- compatibility with architectural choices and the urban context.
A correct coordination between architectural, structural, and energy design allows for the best utilization of the potential of integrated photovoltaics, avoiding purely aesthetic solutions or, conversely, exclusively functional ones.
Common Materials Used in Building Integrated Photovoltaics
BIPV systems use photovoltaic modules designed to also serve a structural function. The materials used must therefore ensure mechanical resistance, durability, and energy performance, in addition to producing electricity.
Among the most commonly used materials are:
- crystalline silicon, used in opaque or semi-opaque modules for roofs and facades;
- thin-film technologies, characterized by greater flexibility and a more contained visual impact;
- photovoltaic glass, used in curtain walls, skylights, and transparent surfaces;
- prefabricated photovoltaic modules, integrated into building elements such as tiles, facade panels, or sunshades.
The choice of material depends on several factors, including:
- the degree of integration required;
- the expected energy performance;
- the aesthetic needs of the project;
- climatic and exposure conditions.
Integration of the Building Envelope: BIPV on Facades and Glazing Systems
One of the most developed areas of integrated photovoltaics concerns the application of modules on the vertical envelope of the building. Facades and glazed surfaces represent extensive areas that are often underutilized from an energy perspective.
BIPV applied to facades allows for:
- transforming the external cladding into an active element;
- contributing to energy production even in the absence of suitable roofs;
- improving the envelope’s performance in terms of solar shading and protection.
In the case of photovoltaic glazing systems, integration allows for:
- maintaining an adequate supply of natural light;
- modulating transparency according to design needs;
- combining energy production and visual comfort.
The use of BIPV on facades and glazing requires a careful assessment of the overall thermal-energy performance of the building, in order to ensure a balance between electricity production, internal comfort, and architectural quality.
Building integrated photovoltaic (BIPV) systems impact the energy performance of buildings not only through electricity production from renewable sources, but also due to their active role within the building envelope. Unlike traditional systems, BIPV directly interacts with the thermal and luminous behavior of the building.
From an energy perspective, the integration of photovoltaic modules allows for:
- reducing the primary energy demand through self-production;
- improving the overall efficiency of the building–system;
- contributing to the reduction of CO₂ emissions associated with energy consumption.
The influence of BIPV also concerns the performance of the building envelope, as the modules can:
- serve as solar shading;
- limit unwanted thermal gains during the summer months;
- contribute, depending on the stratigraphy, to the thermal insulation of opaque surfaces.
The overall effect on energy performance depends on several design factors, including:
- orientation and inclination of the integrated surfaces;
- type of photovoltaic module used;
- level of integration with HVAC and energy management systems.
Integrated photovoltaics represent a solution consistent with design approaches oriented towards passive houses, renewable energies, and the use of digital twins, increasingly used to optimize the energy performance of the building throughout its entire life cycle.
How BIPV Contributes to Zero Energy Building Goals
Integrated photovoltaics represent an effective tool for achieving the goals of nearly zero energy buildings (NZEB) and, in the future, zero energy buildings (ZEB). The production of energy directly on the building envelope allows for covering a larger part of the building’s energy consumption with renewable energy produced on-site.
The contribution of BIPV to zero energy buildings is mainly manifested through:
- increased self-production of electricity;
- reduction of grid withdrawals;
- better balancing between energy consumption and annual production.
In high energy efficiency projects, BIPV systems often integrate with:
- heat pumps;
- energy storage systems;
- smart load management solutions.
This integration allows for optimizing self-consumption and improving overall energy performance of the building, contributing to compliance with the standards set by European regulations on energy efficiency and sustainability.
The installation of integrated photovoltaic panels, replacing traditional roofing elements such as tiles, offers a number of significant advantages, especially in contexts where architectural integration plays a crucial role.
Among the main advantages are:
- minimal aesthetic impact, making integrated photovoltaics a particularly suitable solution for buildings subject to landscape or architectural constraints, where the installation of visible panels and exposed support structures is limited or not allowed;
- high architectural integration potential, as photovoltaic modules can be installed both on existing roofs, replacing traditional materials, and on new buildings, as an integral part of the project;
- good energy performance, achievable provided that the system is correctly sized, optimally oriented, and free from obstacles that may cause shading.
Alongside the advantages, integrated photovoltaics also present some disadvantages, which should be carefully evaluated during the design phase. In particular:
- initial costs are generally higher than those of a traditional photovoltaic system, due to the greater design complexity and the specific materials used;
- design, installation, and maintenance phases require specialized skills and closer coordination among the various professionals involved.
A comprehensive assessment of the advantages and disadvantages allows for determining whether integrated photovoltaics represent the most suitable solution based on the characteristics of the building, the regulatory context, and the energy goals of the project.
Advantages and disadvantages of BIPV
Building integrated photovoltaics finds a particular application in urban contexts, where architectural, regulatory, and space requirements often complicate the installation of traditional photovoltaic systems. In these cases, BIPV allows for the combination of energy production and architectural quality.
Among the main use cases in urban settings are:
- buildings located in historic centers, subject to landscape or architectural constraints, where the visual impact of traditional systems is limiting;
- high-density residential and tertiary buildings, characterized by reduced roofs but large usable vertical surfaces;
- building and energy redevelopment interventions, where the replacement of envelope elements represents an opportunity to integrate photovoltaic systems;
- new constructions in urban areas, designed from the outset with energy efficiency and sustainability criteria.
In these contexts, BIPV allows for the enhancement of otherwise passive surfaces, contributing to the production of renewable energy without compromising the integration of the building into the existing urban fabric.
The installation of an integrated photovoltaic system presents specific criticalities related to the very nature of BIPV as a constructive as well as an installation element. These challenges require careful planning and an integrated design approach.
The main difficulties include:
- the greater design complexity, due to the need to coordinate architectural, structural, and energy aspects;
- the higher initial costs, related to the use of specific components and a more complex design;
- the installation timelines, which must be consistent with the phases of building envelope realization;
- the maintenance, which can be more complex compared to traditional systems.
To overcome these criticalities, it is essential to:
- involve various professionals from the early stages of the project;
- select certified BIPV solutions compatible with the planned building system;
- accurately plan the phases of installation and integration;
- evaluate the life cycle of the system from a long-term perspective.
Before installing a building integrated photovoltaic system, it is necessary to carefully consider the regulatory framework, which can vary depending on the type of building, location, and level of architectural integration.
The regulatory aspects to evaluate include:
- the need for building permits, depending on the planned intervention;
- the presence of landscape, historical, or environmental constraints that may influence the choice of BIPV solutions;
- compliance with technical and safety standards, particularly regarding the building envelope and electrical systems;
- compliance with energy requirements set by current regulations.
In urban contexts and in constrained buildings, building integrated photovoltaics can represent a more easily authorized solution compared to traditional systems, due to the lower visual impact. However, a preliminary check with the competent authorities and a correct design setup are essential to avoid criticalities during the authorization phase.
The cost of an integrated photovoltaic system (BIPV) depends on various factors and cannot be assessed solely by considering the price of the modules. Since the system also serves a constructive function, the expense must be analyzed in the overall context of the building intervention.
The main elements that affect the cost are:
- the integrated photovoltaic modules and the components of the electrical system;
- the design expenses, related to architectural and installation integration;
- the installation costs, generally higher than those of a traditional system.
The final cost is also influenced by:
- the surface area and the installed power;
- the energy efficiency of the chosen modules;
- the degree of architectural integration required;
- the characteristics of the building and the context in which the system is implemented.
The economic evaluation must therefore consider both the initial investment and the long-term benefits, related to energy production and the added value brought to the building.
The integration of photovoltaic technologies in buildings, known as Building Integrated Photovoltaics (BIPV), is an area of growing interest in energy sustainability. However, there is a significant lack of simulation tools specifically designed for BIPV applications that cover the entire modelling process.
In this regard, a study was conducted on Digitalising BIPV energy simulation: A cross-tool investigation.
This study aims to evaluate the effectiveness of 8 existing simulation tools to deal with the complexity of BIPV projects. The methodology of the study involves the use of a real building project with three types of BIPV installations, with the aim of exploring the capabilities of various simulation tools.
The tools evaluated include:
- 3 standalone PV tools (SAM, PV*SOL premium and PVsyst);
- 2 standalone PV tools based on Building Information Modelling (BIM) (BIMsolar and Solarius PV);
- 2 plug-ins in BIM-based tools (INSIGHT for Revit, Ladybug Tools for Grasshopper/Rhinoceros 3D);
- 1 plug-in for Computer-Aided Design and Drafting (CADD) (Skelion for Sketchup).
The study highlighted the need for more advanced and integrated simulation tools to improve the design and performance analysis of BIPV systems. Only through the adoption of more sophisticated and interoperable tools will it be possible to ensure greater accuracy in simulation and more effective integration of photovoltaic technologies in buildings.
The field of building integrated photovoltaics is continuously evolving, driven by technological innovation, architectural needs, and energy sustainability goals. New BIPV solutions aim to improve the integration between energy function and the quality of the building envelope, expanding application possibilities.
Among the main emerging trends are:
- photovoltaic modules with customizable finishes, available in various colors, textures, and degrees of transparency, allowing for greater design freedom;
- advanced photovoltaic glazing systems, capable of combining energy production, solar control, and natural light input;
- integration with storage systems and intelligent energy management, to optimize self-consumption and the overall efficiency of the building;
- prefabricated BIPV solutions, designed as complete building components, simplifying the installation phase and improving system reliability.
An increasingly significant role is also played by the digitalization of the design process, thanks to the use of energy simulation and BIM modeling tools, which allow for a more accurate assessment of the impact of BIPV systems on building performance. The evolution of technologies and materials makes building integrated photovoltaics an increasingly accessible and versatile solution, capable of meeting the needs of contemporary architecture and significantly contributing to the energy transition of the construction sector.
To design a BIPV system comprehensively and integratively, rely on a photovoltaic software that can support you in all phases of the project, from building modeling to energy simulation, from architectural integration verification to the calculation of expected energy production. Such a tool allows for the evaluation of various design solutions, optimization of the orientation and arrangement of modules, simulation of the envelope’s behavior, and prediction of the impact on the building’s energy consumption. In this way, architects, engineers, and designers can make informed decisions, reduce risks and costs, and maximize the functional, aesthetic, and energy benefits of building integrated photovoltaics.
What is building integrated photovoltaics (BIPV)?
Building integrated photovoltaics, known as Building Integrated Photovoltaics (BIPV), is a system in which photovoltaic modules replace elements of the building, such as roofs, facades, or glazed surfaces, serving both an energy and a constructive function.
Can building integrated photovoltaics be installed on existing buildings?
Yes. BIPV can also be used in interventions on existing buildings, replacing portions of roofing or other envelope elements, such as in the case of removing traditional tiles.
In which parts of the building can BIPV be integrated?
Building integrated photovoltaics is not limited to the roof: it can also be applied to facades, glazed surfaces, sunshades, and other architectural elements, transforming them into active surfaces for energy production.
Why choose an integrated photovoltaic system?
BIPV is primarily chosen for aesthetic reasons and due to the presence of landscape or architectural constraints that make it difficult to install visible traditional panels.
How does BIPV affect the energy performance of the building?
In addition to producing electricity, BIPV interacts with the building envelope, contributing to solar shading, controlling thermal gains, and, in some cases, insulating opaque surfaces.
Is building integrated photovoltaics more expensive than a traditional system?
Generally yes, because it requires more design and specific components. However, the economic evaluation must also consider the added value brought to the building and the long-term benefits.
