Photovoltaic installation with two inverters
Why choose a photovoltaic installation with two inverters? What are the benefits for the end user? Discover this and much more in this article
As technology advances, photovoltaic systems become increasingly accessible and efficient, offering an ecological and economical solution for electricity production.
In this article, we will see why using two inverters in a photovoltaic system, how to choose the number of inverters, and what are the advantages and disadvantages of using two inverters.
Also, a video is available showing how to configure an inverter with software for the design of a photovoltaic system.
Outdoor installed solar inverter
Choosing the number of inverters
When delving into the world of solar energy and planning the realization of a photovoltaic system, you are faced with a series of crucial decisions. One of these decisions concerns the number of inverters to use. While some may opt for the simplicity of a single high-power inverter, others choose to install two or more lower-power inverters. But why should you consider this option?
One of the main advantages is redundancy and service continuity. Imagine this scenario: the photovoltaic system is the cornerstone of the building’s energy supply, but suddenly the inverter fails. With a single inverter, your customer would be stuck until it is repaired or replaced. But with two inverters, if one were to fail, the other can continue to operate, ensuring no interruption in power supply.
Furthermore, redundancy offers a kind of “safety net” that can reassure many photovoltaic system owners. If we also consider the practical aspects of maintenance, having two or more inverters significantly simplifies operations. Maintenance on a single inverter is easier and less expensive than on an entire system.
But back to technical aspects, there is another point to consider: performance optimization. With two or more inverters, you have the possibility to adapt the system’s power according to sunlight conditions and the characteristics of the photovoltaic panels. This means that you can maximize energy production, optimizing the overall efficiency of the system.
Flexibility in design is also an advantage not to be overlooked. The ability to distribute power among multiple inverters allows for greater adaptability to the specific needs of the installation site. Energy can be divided based on the building’s requirements or the layout of the panels, thus improving the overall efficiency of the system.
Coordination and synchronization of inverters
Imagine having several inverter units within a solar installation, each responsible for converting solar energy into electricity. For everything to work smoothly, it is essential that these units work together in perfect harmony.
Coordination and synchronization are not just abstract concepts but require detailed planning and accurate system configuration. First and foremost, it is necessary to ensure that the inverters used are compatible with each other and with the system as a whole. This means choosing inverters that not only meet the technical and power requirements of the system but also can communicate effectively and synchronize their operations.
Proper system design is crucial to ensure that each inverter is optimally configured and that all system components work together cohesively. This includes choosing the right voltage and frequency settings, as well as managing electrical connections to ensure a uniform distribution of energy.
Coordination and synchronization are not only about energy efficiency but also about the overall system’s safety. Inadequate inverter synchronization could lead to overloads or voltage fluctuations, putting the system’s integrity and people’s safety at risk.
Performance and reliability of inverters
The efficiency of inverters is closely related to the amount of energy they can convert into usable electricity. High-quality inverters, designed with advanced technologies, tend to offer higher efficiency, allowing to maximize the available solar energy. Optimal efficiency results in increased energy production and, consequently, a higher return on investment for the system owner.
However, efficiency is not the only factor to consider. The reliability of inverters is equally important, especially considering the expected lifespan of the photovoltaic system over time. Inverters must be able to withstand adverse environmental conditions, such as extreme temperatures, humidity, and voltage variations, without compromising their performance.
Moreover, the durability of inverters is a key element to evaluate. Photovoltaic systems are designed to operate for many years, so it is essential for inverters to have a long service life to ensure long-term profitability of the investment. Investing in reliable and durable inverters can reduce maintenance and replacement costs over time, helping to preserve the system’s value over the years.
Indoor installed solar inverters
Advantages and disadvantages of a two-inverter system
Now let’s summarize the advantages and disadvantages of adopting two inverters for a photovoltaic system.
Advantages
- greater flexibility in optimizing system performance – by using two smaller inverters instead of one larger one, it is possible to more effectively adapt the system to various operational and environmental conditions. This allows maximizing the overall system efficiency, adapting energy production to the specific needs of the end user and fluctuations in weather conditions. Additionally, thanks to the ability to separately control each inverter, it is possible to optimize the system’s operation more precisely and personalized, further improving the overall performance of the photovoltaic system;
- greater system resilience – having two separate inverters instead of one makes the system less vulnerable to sudden failures. In case one of the inverters does not work well or requires maintenance, the other inverter can continue to operate independently, ensuring a more reliable service continuity. This redundancy is crucial especially in situations where constant energy availability is crucial, such as in commercial or industrial contexts;
- improved management of operational and maintenance costs – since smaller inverters tend to be less expensive to purchase and install than larger ones, this configuration can offer an initial financial advantage. Furthermore, maintenance and replacement of inverters can be managed more efficiently, with fewer interruptions and overall costs over time.
Finally, the evolution of the market and photovoltaic technologies should be considered. Opting for two smaller inverters instead of one larger one can offer greater flexibility and adaptability to future industry innovations and developments. This way, long-term investments can be protected, keeping the photovoltaic system up to date even in the face of technological and regulatory changes.
Disadvantages
Although adopting two inverters for a photovoltaic system can offer several advantages, it is important to also consider the disadvantages associated with this configuration. Here are some of the main disadvantages to consider:
- additional costs – using two inverters, instead of one, generally involves additional costs related to the purchase, installation, and commissioning of the system;
- installation complexity – connecting two inverters requires a more complex design and installation compared to a single inverter. This may require more time and resources from qualified personnel, potentially increasing project costs and completion times;
- additional space – installing two inverters may require more space than a single larger inverter. This can be a problem in case of space limitations on the roof or in the area where the photovoltaic system is positioned;
- maintenance complexity – managing two inverters instead of one can involve greater complexity in maintenance and issue resolution. It is necessary to monitor and maintain each inverter separately, which may require more time and resources to ensure optimal system operation over time;
- possibility of performance discrepancies – even if identical inverters are used, small performance discrepancies may occur between the two devices. This could be due to variations in operating conditions, aging, or other factors, which could slightly reduce the overall efficiency of the system.
How to configure the inverter
In this video, you can see how to configure an inverter with software for the design of a photovoltaic system.
